1150GS - What does the clutch switch do?
ducatiparts.110mb
Anglesey
I assume the switch is just there so that you can only start in gear if the clutch is pulled in and it serves no other purpose.
Does anyone know otherwise?
Thank, Mark
The Haynes manual.....
says and I quote......
The switch is part of the safety circuit which prevents or stops the engine running if the tranmission is in gear whilst the side stand is down, and prevents the engine from starting if the transmission is in gear and the side stand is up unless the side stand is up and the clutch lever is pulled in
:D
