Feltwell
Not used the GS much since I came back from the TT. Went to take it for it’s MOT today – strange, gear indicator isn’t working.
Got part way there and the bike was really playing up – go to pull away from lights and at about 5mph suddenly there would be no throttle at all, worse still was it would cut back in with no warning and with little relation to the twist grip position! Sometimes it would be OK, sometimes it would play up. Nursed it to the MOT place, it passed (!). Riding it home through rush hour traffic was just horrible – throttle would stick on, throttle would stick off, finally found that you could pull away in first to about 5mph, then change into 4th and slip the clutch like mad and it would behave, most of the time. A bit interesting trying to turn right across busy traffic with no idea if the throttle would respond or not…….
It seems that the gear position indicator switch is a known fault on older GS's, but I don't see much for the LC models. From my bike it appears if the ECU doesn’t know what gear it’s in it sends the whole bike screwy. Why do they have to make them so bloody complicated now? If I'd had far to go it would have been a recovery job, the bike was dangerous to ride.
Put the GS911 on the bike and the only repeating fault code was for the gear position indicator switch.
So, came to take it off. The switch is on the back of the gearbox, just up behind the gear lever - dead easy to get to, 2 screws to remove, no strip down required. At least that's what I thought until I realised the connector was nowhere to be seen. Haynes manual says you have to remove the starter motor to get to it, and they're right, and that is a right pain as the rear fixing bolt for it is very difficult to get to with the swingarm in place. It is possible to do it without removing the swing arm but it's damn tight and requires the right tools! What a bad design. No way could I have disconnected it without removing the starter motor first, then I found it was cable tied tightly in place behind the connector as well.
Got the switch off and it's let moisture and dirt in past it's O ring so I'm confident it's failed. I'd recommend taking it off - as without disconnecting it is literally a 2 minute job - and putting some silicone grease around the O ring prior to refitting, make sure no moisture can get past it. If anyone wants a picture of where it is I'll post one up, but it's easy to find.
New switch on order - £105 from Moto Works, but I got a new old stock one off Ebay for £70. Hopefully that will sort it.
