1150GSA MRA Vario Screen
mad-dawg
Harrogate
Bought a Vario screen and want to use it with Tobinators, does anybody know what additional parts are required please?
If you can waiting until it's light I'll take some photos of mine but I can't actually recall, without going all the way down to the garage if there were 'additional' parts.
Thanks Steve
The mra screen has a big hole for the front fixing and the adventure plastic covers don't have a spacer to fill the hole.
There's threads on here about this but nothing with a close up pic.
You need the fittings for a standard 1150GS screen. You unscrew the adventure screen pods/winglets & use the standard ones in their place. However, if you can't get any 2nd hand they ain't cheap new. Circa £50
Parts no.2 & 4 here
http://www.ascycles.com/Illustrated...&bindName=Front_panel_carrier&bindCat=46_0603
And parts 2,3,4,5 & 6 here
http://www.ascycles.com/Illustrated...Name=Windshield_mounted_parts&bindCat=46_0604
If you want to also use tobinators, you normally need the std tobinator kit. Which ones have you got, std or adv tobinators?
Parts no.2 & 4 here
Thanks Jon
Happy days! another £50 to use the MRA screen plus I have the Adv tobinators so would need the std fittings for that as well so looks like a nearly £300 total outlay.
My fault for not researching this more before buying the screen.
Not sure I can be arsed to spend another £150 to try a screen that may or may not cure the buffetting.
I thought Tobinatirs were designed to cure problems with the original screen. Namely turbulence.
Aren't these turbulence problems cured by MRA and so Tobinators are no longer necessary?
Or am I missing something. A further problem specific to the 1150.
Just curious.
You 'might' be able to use/bastardise the adv tobinators if you have them, I can't honestly remember - have a look at the pics of them.
You can try the MRA without tobinators, tall sods like me need them (6'3").
Motobiker - normally the MRA cures it, but using tobinators gives you a whole new range of adjustment. I found the std MRA was okay, but the tobinators cured it completely
You could always ask if anyone's near & got the std screen fittings and see if they'll loan them for a ride - takes 5 minutes to fit & you'll know straight away. I'd loan you mine, but I'm a bit far away :)
Just curious.
Yes, I tried Tobinators with an mra screen for a long time but the screens much better without them..... Just to confuse things :D
Thanks for the info.
Like you I'm 6'4" and need all the streamlining I can get!
Think I will make it a winter project and make some spacers for the holes in the MRA, what can possibly go wrong.
