A couple of questions from a GS newbie.
Have an '03 GS Adventure (single spark) with servo ABS.
1. The front brake seems excessively "grabby" - in that if I squeeze gently, it is progressive up to a point. Then the brakes seem to go from being on gently to on pretty damn hard in a tiny pressure change at the front brake lever. Not a problem at speed, but *really* not nice at slow speed (filtering / traffic / manouvering etc.).
Is this a feature of the servo ABS system, or does something need adjusting / bleeding?
2. The "squeeeeeeeeeeee" noise as you hold the brakes on. Comedy value wore off the first time I stopped on a hill. Can anything be done to shut it up a bit (that doesn't involve ripping out the ABS)? Is it related to #1 (i.e. something needs adjusting / bleeding).
Thanks,
Paul.
Thanks,
Paul.
