david a hall
My thoughts exactly. It`s what warranty is for....![]()
you are exactly right
Good advice but the bike does not have servos. The front brake is pretty conventional.
As has already been said ............. does it have any fluid in the reservoir? The bike has just had a front brake pipe changed surely this is a clue.
have pumped it twenty times but its just flapping about but thanks for your opinions dont know about bumping me off ,there is a recession on you know and i did spend all my money on this piece of german engineering![]()
I'll defo keep an eye on my brake lines from now on, also test the front out more often. Let us know how you get on...I woke up one night to find my GSA trying to smother me with a pillow.
And it's got ABS.
With all due respect, I would suggest getting into the habit of using just the back brake seems like a recipe for disaster - if one day you ride a 'normal' bike - without coupled brakes - and your 'habit' kicks in, you are going to get terrible braking effect and at worst a painful meeting with whatever was in your way![]()
Hmmm, don`t quite understand that one.
Like Stevie, I tend to use just a touch of back brake to slow in town. I also only use the rear on twisty roads to settle the bike rather than keep on the front brake. I do keep the front brake covered though
Mine doesn`t have ABS or linked brakes though![]()
I don't need the front brake, but if I have to stop a quickly from a higher speed, then I use the rear brake first, then apply the front and increase the pressure accordingly to the distance I have. At this point, more emphasis is on the front brake, whilst letting off the rear if I need to...I'm not the most experienced rider by any stretch of the imagination, but I always feel safe braking like this, and the bikes have always felt planted to the road in emergencies....
