1200 Twin cam Wiring Diagram for Aux lights
DrFarkoff
Grumpy Ole Git!!!
Islandmagee, Co Antrim NI
Would anyone have, or be prepared to share the wiring diagram for me
I have the earlier manual but would like to verify the trigger wires and connections for the OEM factory Fog / Driving lights with the switch mounted up on the top of the left switch gear
cheers
Jay
Not the best quality diagram but here you go
Thank you
Much appreciated
So there are fuses Apparently someone said there were and I thought all the systems are controlled by the Central Control Unit
Would you by any chance know where to look for those fuses @Fifth Horseman ??
Thanks for the Info so far
The aux lamps are not controlled directly by the ZFE hence the fuses. They are in a small block that looks like a blanking connector under the black cover on the left hand side.
Cheers for that Thank you (y)(y)(y)
Sorry to bother you again, is that a Twin Cam or a Water cooled as someone sent me the installation guide and its is supposed to be up by the front right fog lamp
Twin Cam - I've pm'd you the installation instructions for the hexhead/twin cam bikes.
Got that Thank you Its been a busy day
A Hardy Day!! A Laurel and Hardy Day more like! Another fine mess I got myself into!
the switch in your instructions resembles the one fitted to this So I presume the fuses will be in a similar place to yours
Thank you for the Help
My 2006 adv has the fuses under the black cover around the tank on the throttle side of the bike.
Just to let you know there must be different locations for them.
I think that is the difference
TC have them left side behind the tank side panel near the seat behind the chassis plate and pre Twin Cam have them up on the front at the right behind eth Fog lamp just inside body work ?
The earliest GSA's that had the aux light switch on the handlebar did have the fuses on the right hand side. I did a bit of extra research and it appears that on the earlier bikes the fuses were in different positions. On the earliest bikes with the switch on the handlebar (0382) they were under the right front side cover, later (model 0380) it appears they moved to the left front (the manual is a bit unclear about this), then with the last (09/2009-on, 0470) models they moved to the position I described. I only found this after checking the different online owners handbooks, BMW's RSD unhelpfully only shows the one location for both the 0380 and 0470 models.
Both 0380 and 0470 models had the aux light switch above the left hand switchgear.
