Uncle Ricky
When did the so called electric problems start with the 1200GS , ie which year and should it put me off getting one
SOME BIKEs HAVE PROBLEMS SOME DONT for the most part they are few and far between, the only reason people think the 1200s have leccy etc etc problems is the fact that BMW have sold many times more of them than any other manufacturer, so with that many bikes out there, your bound to hear of the odd problem.When did the so called electric problems start with the 1200GS , ie which year and should it put me off getting one
Any year starting with a '2'
2 general probllems with the 12GS...
Ring antenna (takes key signal and let's it start)
Fuel pump thingy..
Both have very simple road side solutions... Now stop worrying and buy the bike and enjoy..
Fuel pump thingy..
As per wilbjr21 's comment - Spot on, and the later the better with 08 onwards having fewer reported electric component failures
Mine is a 2005 standard GS - never had any electric problems, some early ones had fuel pump problems mainly cos the numpty owners let the surround fill up with water and they corroded. - duuurrrr!
Yeah true some did, but I was in Australia at over 30 degrees and the damned thing on my 2004 bike decided to stop working after 4 years of reliable performance for some other reason. The part I replaced it with was a modified part and no problems since.
As has been said already, DONT let it put you off buying a 1200 because they are great machines. Carry a spare FPC/Ring Antenna on longer journeys (and Torx screwdriver that fits it 'cos the toolkit ones don't) and relax.
