I have the SW-Motech upper bars on mine, a bit shinier than the OEM lower bars, but not a bad match. Regards the spots though, the upper bars use the same fixings as the OEM spot bracket, so on mine I bought a pair of Denali spot brackets which I fitted to the tube of the upper crash bar once I'd fitted the bars themselves (I slightly shortened them as I prefer the spots closer to the bar, also it gave a bit of slack on the spot wires themselves, otherwise it was a tad tight). The upper bar of the Motech is a slightly smaller diameter than the OEM lower bars so if you do go this option, just make sure you get the right diameter Denali brackets (if you need to know the diameter or which brackets let me know and I'll see which ones I purchased)
