First post....
Picked up my KTM SA S (orange) 2 days ago and am on 380 miles into the running in period - I just can't get off it. Compared to my old GS TC it's like chalk and cheese! Breathtaking acceleration, amazing suspension, comfortable, flick able and exhilarating. The quick-shifter is superb especially on downshifts, great sound from the Akropovic (much better than the asmatic stock can). The Hill Hold Control thingy takes a bit of getting used to....still not sure about that. The TFT display is a revolution- all bikes should have one, very customisable, clear, informative and switches between light and dark perfectly.
Luggage...the KTM panniers feel a little flimsy, small and cheap plus limited to hold up to 10kg so you can't add extra bags on top of them. The top case even worse as it's limited to only 5kg (my Almax chain is something like 12kg!). They use a floating plate system that doesn't fill me with confidence. Plus of course with luggage KTM advises a max speed of 90mph.
If I had seen the system before buying I would've sourced another solution as they were not a cheap option.
So to sum up - the engine is superb, even restricted to its running in 6000rpm, the brembo brakes are amazing, it gives you the confidence to really attack corners while still feeling very planted and comfortable. Heated grips are better than the GS and frame/build quality also I feel better than my old GS.
Pants expensive luggage system IMO and the mirrors are a little "vibey" at speeds over 80mph.
No idea about mechanical reliability, future value retention, corrosion resistance or electronic reliability but I've researched an upgraded DID chain and sprockets set for when the time comes (and it's much cheaper than a shaft drive overhaul!).
The headlight isn't a gimmick either...it's superb and I don't get buffeting from the screen.
Next week it's in for its 600 mile first service and will then allow me access to the engines full rev range. Also it's much better to look at in the flesh than on paper especially with the optional orange crash bars and radiator guard.
I'm fitting a Scottoiler too
All in all I'm very happy with the bike so far.
230 miles from the tank (approx) at 61mpg (indicated on the display)
