12GS 50,000 km report
I also have the E360 Givi top box, same as in your picture but without the rack. I found that by taking out the document holder in the lid, I was then able to fit two full size crash helmets in it. In your case I would make sure the screws holding the rack on don't make it even harder as its a snug fit. Also beware that riding around with a helmet in the back box your helmet could possibly get scratched as mine did. If possible use one of those helmet carriers that come with the helmet. (Those think crappy things). Or rap it in something. :thumb
Jay
Where did you find these light switches (and mount) ?
How about corrosion?
SQD8R
Any problems with corrosion? I suspect your machine has seen a fair bit of salt and water. What "normal wear and tear" (BWM phrase) have you seen and on which parts?
G
Kropotkin said:
Is the Givi top rack any good? I've been thinking about getting one for my E460. I would fit a large (but light) roll containing foam sleeping mats to it, but I was worried that the wind pressure might tear it loose, or at least cause it to leak. So, is it strong enough and can the fitting be made waterproof?
The Givi rack is excellent. I use it regularly, mainly for my rain suit, in a compression bag, or my air mattress in a dry bag.
Outtomunch said:
Great write up, thanks :thumb
There's plenty of food for thought there but re. the Fastway pegs, how much do you find they compromise ground clearance when on the lowest setting. I'm in two minds whether to get them or not as this is a real concern of mine.
Andres
I find no compromise but the little they move down relieves my knees just that bit more so the ride is much more enjoyable.
Steve Pickford said:
Not bad for an air/oil cooled bike or am I missing something. :nenau
:eek
I must have a had a KTM 950 on the brain again. :rolleyes: My mistake. I meant the fuel pump o-ring as Mouse says
TheJoker said:
SQ - excellent! I'm just waiting for your drinking buddy to show up! :beer: :beer: :D ;)
When/where did you post about the utility box? I also want something similar! :D
:thumb
Thanks!!
I'll post up the info for the pelican case in a separate post. Lots of pics and very useful. I've added the padding that comes with it and pared down the tool kit so that it's tight but easily closes.
kdude said:
:beer:
Recalls:
1. O-ring on the waterpump. 1/2 hour replacement time ..... NOT MINE ..
Problems:
1. Neutral light went out, reset @ service interval. Problem was recognized as too much water exposure
2. Centre stand bolt sheared and I believe it is going again, but don't quote me on that one. HAVE A PIC OF THAT PROBLEM ?
Where do you usually ride in the OTTATA area. DO YOU HAVE ANY GOOD ROUTES USING BACK RDS TO TO ? GOTTA RIDE MTL ---> TO TO VISIT SISTER NEXT WEEK.... OH YEA DID I TELL YOU THAT YOUR LIGHT SET-UP ROCKS ! AHHH MAYBE ONE DAY ! :bounce1
hp
I've only used Metzelers and my mileage is always out of town, I hardly ridein the city so the mileage seems to last better. I find tire pressure is very sensitive. I set mine cold and check it weekly esp. before and after a trip camping where it carries more of a load.
My bike is an '04 model so I'm guessing the recall won't apply to your '05. Sorry no pic of the problem. I first noticed it coming back from Deal's Gap, fully loaded for a week of camping. It became increasing harder to get up on the centre stand. I just guessed that it was me being fatigued esp. in the heat of the US south in July. I sheared it and I still have the bolt so I'll take a picture and add it to this post tomorrow. I don't feel I was ever overloaded and assumed that when I initially owned the bike, rolling it off of the centre stand might have twisted it to one side. But since the replacement I haven't been rolling off of the centrestand while on the bike so I can't explain it. Perhaps loaded with gear it's simply too much for the bolts. If it does go again I'll look into a more stout bolt.
I usually head up to Calabogie, down 41 to and across to Oompah and in that area. Recently I've been riding to the Adirondacks and last weekend to the Cromag rally in NH. I'm heading up to either Gaspe Penn or Manitoulin Is. this weekend. Get it in while I can enjoy the weather.
I use highway 7 to Peterborough, cut across through Port Perry instead of following 7 up to Lindsey and then again onto 7 through Orangeville, over TO onto Elora Gorge to be past TO. Then I'd drop down to 14, it runs parallel to 2 but is much faster due to less traffic/police presence. I usually do Ottawa to Windsor in 7-8 hours of actual riding time.
Jay
Thx Jay, much appreciated.
These switches come with the light kit. The mount is just a piece of plastic, melted to fit in that position. The way we mounted it was to take the bolt that holds the front of the mirror mount, if memory serves out, add in some metal washers, as shims to make the mount flush with the top of the bracket and then bolted it back in place with the plastic mounted. I'll take some better pics tomorrow.
Gonzo said:
SQD8R
G
I'm an interior boy so we don't get the exposure to salt that you get, nor do we get the amounts of rain you get. I've had no issues with corrosion but I'll give it another look tomorrow just ot be sure.
Warranty
Hi super report on the 1200GS and your obvious enjoyment of it.
:rolleyes:
Just a question over aftermarket fitting of the lights, does this alter the BMW dealer warrenty in any way?
