Hi, many thanks for all your responses, sorry I didnt reply earlier.
Ad: Adjusting the screen:
I have played with the screen position the first 1000miles after I bought the bike, finding the "right" for me and have not changed it since then. So I don't think this is an issue.
While you are at the front of the bike just check the Torx pinch bolts that hold the fork legs into the bottom yoke - these seem to have a habit of loosening off (its unlikely to be this but elimination is the name of the game)
This has been checked by BMW dealer when replacing the front suspension and the forks oil.
...as you have spoke wheels, it worth checking the "run out" on them - should be within 3 mm I think - just stick the bike on its centre stand and rotate them for a quick visual...
Good luck
Done that personally and also this was the first thing the dealer looked at. They are within limit. Checked also the balance of the wheels.
Check the bolts of the bridge holding the forks right above the front fender. If you say the hadlebars at standstill feel soft that might be it...
Will do, whenever I got my bike back, it is stuck with the dealer over last almost 2 monts..
I've just bought a new 2008 1200 GS and I know exactly what you are referring to as I get the same feeling. I put it down to my being a well built person and I have been told to gradually increase the rear shock pre-load testing it each time as this will eventually cure the problem.
john1215
I agree the "well build" riders may cause a bit different bike behavior, but my bike was perfect the first 16,000km and I did not put on any weight since I bought the bike... And still, Im only 100kg - the bike is not made of wax, is it?
Tight steering head bearings will give you the symptoms you describe.
This is my estimate too, however the dealer said it was OK...
... In most cases the people forget that many of these problems come from the back part of the motorcycle; (see it first)
I did and the dealer did; all is tight, in line, no problem...
... When you find the problem, please tell it.
I certainly will!
if it started at 16000km without you having changed something, then I suggest that its a problem of wear on some part of the bike. looseness of some sort which is varying the alignment of the bike whilst on the road. but the problem is finding something like that.
Absolutely agree!!
...I suggest you systematically work your way from the back of the bike to the front looking at the basics like wheel bearings, play in the bevel box, wheel run out, then suspension mountings and particularly the subframes and their mountings etc. What you are looking for is something that should be tight and was when the bike was new but is no longer...
I would love to, but as I said, the bike has been with the dealer(s) for almost 2 months still discovering...
Assuming it is not something simple (tyres, suspension...etc) I am mainly worried about some cracking in frame and similar...
