You seem unsure about things:
You must take the bike to a dealer - for safety and your own peace of mind
You must take the bike to a dealer - for safety and your own peace of mind![]()
Tried it already, seems to be fine
One quick way to put your mind at ease is using a length of string.
Take the string (need a buddy to help here) tie it around the front rear rim and run it back under the bike - do the same with the other end around the front of the rear rim.
Arrange it so the string is tight and the knot on each tyre is exactly in the centre of the tyres. This gives you a straight line down the centre of your bike (assuming you have someone holding the bike upright, steady and with the handlebars dead centre).
The string should run directly under the centre of the main engine block - best viewed from under the bike using the front of the engine case and rear of the engine case as a guide.
If there is any twisting this should show an out of alignment in one direction at the front and the reverse direction at the rear.
Best of luck with it!
One quick way to put your mind at ease![]()
.......sorted then
Summit wrong with that advise then El Capitan...?![]()
Takes 5 mins with a buddy - can be done on the centre stand but needs more care. And I suspect he like to have his mind put at ease (if it really is out of line - I'd sooner NOT ride it to the dealers).
Best of Luck (for sure for sure)![]()
No mate, just playing... I was just thinking about going through the process and I found it funny....I had this vision of four guys, two with string one holding the bike up whilst the other is lying on his back under the bike his legs either side of the rear wheel looking up
It makes good sense- I agree![]()
I think there must be some greater tolerances, with it being designed for off-road. After all it's not a finely tuned highly strung sportsbike designed for nancy power rangers.
