12v Ignition Power connection
BeeMEir
Galway, Ireland
Hello All, I am fitting Garmin Action cameras to my 2020 R1250GS Adventure, and rather than using the DIN socket is there 12v Igntion power connections in the front and rear of the bike? if so where?? Thanks BeemEir.
you could piggy back it off the sat nav prep connector down to the right of the forks, tucked away inside the fairing?
you would need to pull the plug and check the wiring, but that at least gives you ignition controlled on /off
