ninjarich1971
Ok so I’ve got a usb point wired directly to the battery for charging stuff up on trips etc. My problems are that obviously if you park up you have to remove whatever you are charging and it’s not mega practical when riding if I want to keep something charged.
So my thoughts are a bulkhead fitting into the top box and then I can just stick an extension lead from the socket to the top box which will unplug for removal. On the inside it just needs to be usb female.
Obviously it needs to be waterproof, but not necessarily usb going in.
Anyone done this or any ideas would be appreciated. Cheers
(ignore 2.5mm jack plug. that was for something else)
