If you want to avoid over-current problems (you haven't said what you're running), use a relay.
Wire the relay's actuation coil to the accessory plug + and -, then make a wiring run as follows:
Battery positive --> Appropriate fuse --> switched relay terminal 1 --> switched relay terminal 2 --> 12V accessory terminal 1 --> 12V accessory terminal 2 --> Earth point.
This will give you a handy 10-second delay after switching off the ignition, before power is cut off.
