I'm looking for case studies of people who have run a heavier 50 weight oil in their liquid cooled BMW. Specifically the 1200. Which are meant to run 5w40
And if they have found any problems or benefits over 10,000 miles of use.
Thicker oil arguably provides more long term protection. But also more friction. So lower mpg. Harder cold starts and more strain on small batteries.
Manufacturer oil recommendations are based as much on economy and efficiency (Euro standards) as much as they are with engine health. We can see this in the car industry as oil weights get lower and lower.. Even zero weight oils to improve efficiency. At the cost of catastrophic engine failures.
This can also be seen with the retrospective swap to 80 oil for BMW bevel drives from 75w90.
However, swapping engine oil isn't that simple. Engines could have tolerances that a thicker oil doesn't penetrate. Or
oil jets that can not spray far enough etc.
Any case studies here ?
Cheers.
Cheers.
