Well I decided to have a go at my first valve Adjustment on my 1100GS (with H&B Bars)
Did all my homework and all ready,
1st issue, getting the lug out of the view hole, bit difficult with the bars in the way, but managed, just with a very long screw driver.
2nd, Just couldn't turn the back wheel to turn it over, bugger, lets take the cover off..... damn, Bars are in the way, so I loosened all the bolts (Except under thank tank), finally managed to pull the bars forward enough to drop the cover of the front.
Glad i loosend the Bars otherwise I wouldn't have been able to get the cyclender covers off
3rd, after finding TDC, which have to say was very easy by turning the crank at the front, found valves to tight ???? instead of 15mm they were 13mm and less than 30mm for the others, mmm I was expecting valves to loosen not tighten, or am I wrong. Any way adjusted them to the book 15mm & 30mm. didn't find this too difficult, thank fully. The other side 15mm, and less than 30, at least one pair were right.
Put it all back together, Putting the lug back was pain... bars in the way, and the front cover.... again bars in the way.
3 and a half hours later, moment of truth,...... yep it starts
So what have i learnt,
...... Take the Bars off
, even if I get a garage to do it
Question though, would you expect the valves to get tighter?
