itspilsbury
As my rear pilot 3 was badly feathered (6400 miles) and down to 1mm on the lower side of each tread groove I decided to have a go at changing them myself ....
I have fitted Tourances (not EXP) ready for Morocco in October.
I have also changed the valves for aluminium angled ones.
How did it go? Bloody hard work and I scratched my rims!
Firstly the valves - I put the tiniest amount of fairy liquid around the hole in the rim to help the rubber seal seat, put blue loctite threadlock on the threads and tightened the nut by hand with a spanner fairly tight to what I thought it should be (no fitting instructions with them). Have I done right?
The tyres - the front was the hardest ! I purchased some rim protectors - they wouldn't fit the thick GSA spoked rim! I tried pieces of plastic cut from an old 5 litre screen wash container, I tried some 4mm thick rubber.
The levers cut through and marked the rims which I have touched up with a black car touch up. Any advice please as what to use to protect the rims which works?
Ian
Ian
