Hi Guys,
After some advice and opinions regarding a fault with my bike, when applying the front brake, whether lightly or heavy, I get a pulsing sensation through the brake lever. I have overhauled the front brakes (Evo type, BMW Branded with Brembo on reverse side) with new brake discs and pads, new pistons and seals, plus fresh brake fluid. No fault with the ABS system, back brake is fine and I'm wondering whether the fault could lie with the brake lines. Did the bike come with stainless braided lines as standard, as mine is fitted with them currently. I had previously been advised the inside of the brake lines could have degraded and cause this fault?
In addition when the front brakes are applied I hear a mechanical clicking sound from under the tank, ABS pump? Is this normal, only heard it as I was riding the bike without my helmet as part of the fault finding process! As previously stated the ABS system works fine, with not faults displayed, but the sensation at the lever when the front brake is applied gives that on/off ABS feel! ABS ring is clean and free from corrosion, could the ABS sensor produce such a fault?
Any help or advice welcomed.
