2003 1150 GSA re build thread in 2020???
Bennyk@
Australia
So I've been going through the threads and have not really found what I'm looking for.
So this is what I'm looking at doing with the recent purchase of an r1150GSA non ABS with a bottom end bearing on the way out.
The gearbox and clutch are strong and I have an R1150rt-p sitting there with a strong motor and dodgy clutch and possible gearbox. I've been told a motor swap is easier than trying to fix the bearings so that's what I'll be doing. How ever while I'm going this far I thought I may as well re spray the gearbox as it has no paint left on it. Then the heads look a bit ratty so may as well do them then the sub frame could use a beef up while I'm at it.... do I change the FD and paralever colour ,re spray motor?. Where do you stop?
So yeah It's going to get a bit full on but I can't find any build threads like this for info and ideas so am wondering if it would be worth while documenting this journey or are there already threads out there but I'm not using the right wording in the search bar?...
Also I' new here so have not figured out how to upload photos yet to write about each photo so yeah bear with me....
Any thoughts?
For a start the cylinder head studs are different between the RT and a GS - 3 verses 2
Welcome Benny, there are a few guys on here with tremendous knowledge (unfortunately I’m not one:blast) the likes of Mikeyboy, Steptoe and Drfarkoff in the Emerald Isles are just a few. Plus we all love following a well documented rebuild thread. Ian J Hartley on electrics is another. Good luck. :beerjug:
They are, but you said you were going to swop the complete engine.
Yes that's right but I didn't go into full details I guess. The heads will be getting a blast so I can 2pk them with ease also the gear box then I'll be slapping them on the rt motor. I will point out at this stage I'm a crane op/Rigger not a mechanic so my knowledge of interchangeable parts is shall we say limited Steptoe...
