grahamf505
Hi All
Posting for a bit of advice here before I rip out the Servo and ABS from my 2005 1200GS. A bit of recent history first....
Had the fluids changed in the brake lines/cylinders/reservoirs/ABS before Christmas by those great guys down at the Stroud Motorcycle Company as a precaution. Hadn't been changed for at least 3 years. Brakes were superb after the fluid change. It seemed 'I'd got away with it' as the guys did warn me there was a possibility on a bike the age of mine that replacing all the fluid might cause a problem given there might be loads of muck in the ABS/Servo reservoir (which there was).
My joy was short lived! Last week, the red triangle came on with the brake failure light flashing continuously. Still had brakes (as you do), but braking obviously compromised. Only other symptom was my rear brake light being permanently on. Not noticed that before, so i'm guessing that's related somehow.
Took it out again yesterday. Oddly, after about 20 mins of riding and 10 miles, everything started working as normal again, but the rear brake light was still on when I pulled up to check. After turning the ignition off and back on, again, no servo.
Between the original failure and it coming back to life yesterday, I ordered the 'bypass kit' from motorworks (the two bits of pipe) as I'd assumed it was dead and I don't have the funds to go for a replacement ABS/Servo job. My plan was to rip it out and go back to non-ABS. In any case, I've spent 45 years riding bikes with no servo or ABS, and sometimes no brakes either ;-).
Before I do any drastic surgery, thought I'd put a post up here and get some thoughts. Is the Servo/ABS likely to be knackered given the symptoms (including the permanently on rear brake light)? If they are knackered, do these things ever come back to life, or once they die, they're dead. Just wondering whether it might be an electrical gremlin that could be fixed before I make any decisions.
Thanks for your help!
Graham
Graham
