2006 gs battery speedo and rear light problems can anyone help
andrew darwent
Member
cheshire
recently bought a 2006 gs which would not start .Replaced fuel pump and cleaned filter problem solved .But now have other issues as listed Battery is being drained from full to nothing overnight with everything turned off speedo does not work and rear brake light is permanently on Can anyone help cheers
Sounds like abs module failing mate
Which abs do you have? My brake light stayed on all time, i had a pressure sensor fault, i split the old hydraulic block off and fitted used hydraulic block to save me coding, on my diagnostics it showed a constant pressure on rear brake circuit , Thanks
Unplug the ABS module overnight and see if you have any power the next morning ??
cheers for info i will start with the basic stuff first before i start stripping the pump i do have the lights on the dash now so will keep you posted .Does the abs also affect the speedo
If you go for a ride with the unit connected, then park up, Pop the side panel off and lift out the ABS unit Plug
Just check if the bike will start and then shut it down and leave it as you would every evening
If you come out in the morning and the battery is flat then it was not the ABS unit!
If it is flat ?? Take it out charge it and take it to a motor factors or garage that deal with batteries and have them test it properly!
Don;t go diving in headlong loading a parts canon and just firing stuff at it or stripping stuff down without research !
#DiagnosisIsKing
