2006 immobilizer reprogram
db-89
Galway
the immobilizer fob on my gsa went dead and i didnt replace the battery for a month and now it wont work.light flashes and it was working fine .i cant seem to find anything online for the k25 online. does anyone know how its done?
Thanks:friday
Thanks:friday
Depends on what you want
Registration mode , to register the unit (fob), up to four units only
Sync mode
Battery change mode
Start with battery change mode
After changing the battery LED 3 should remain on - the fob requires Synchronising
holding the fob in range of the reciever (bike) press and hold button 1 twice in quick succesion
Led 3 should start flashing and go out a few seconds later
Fob should now be syncd to the bike
To sync fob when battery ok or you've been playing plipper wars ;)
Press and hold button 1&2 - Led 3 flashes
Led stop flasing after 10 seconds
Release buttons 1&2 LED should remain on
Press button 1 or 2 Led should go off
Fob should be syncd
mine is the 2 button tyre fob with a single led.when i replaced the battery it did flash numerous times. when i tried the button 1 bush twice it didnt do anything
Thats the intsructions from a 2006 unit 2 buttons & 1 led
Take the battery out and start again ;)
Your a star mate. was just being an egit.worked perfect.thanks for your help
If you don't have the Manual for the alarm, perhaps you may download it here.
http://www.bmw-motorrad.com/com/en/index.html?content=http://www.bmw-motorrad.com/com/en/services/manuals/manuals_main.html&notrack=1
The tricky part about finding the manual for the alarm is that while it is listed under Original BMW Accessories, it is not listed under the "R" models selection.
You will find the alarm manual under the "K" models selection. And there are manuals for several different years. E.g If you want the -2004 manual, search for the K1200R, while the -2006 manual will be listed under the K1200GT, and -2008 under K1300GT.
It would be more clear if they had listed the Alarm manual under the Universal category, as it works the same on different models, but for some reason they don't.
Anyway, the manual is in there, and may be downloaded without any restrictions and free of charge.
