as the title says, and in contrast to the smoothness of my previous 04 model GS. What changed with the update in 08? Did BMW change the gear ratios in 1st and second? Did they increase the idle speed? Change the throttle sensitivity?
which means there will be no change to how the engine runs in closed loop mode. ( when the lambda sensor input is used to alter the fuel ratio).If you don't go the remap route as I did, there will be an Accelerator Module and/or Wunderlich Fuel Controller up for sale soon. Send me a pm.
Dont see, able to send a pm Beemerman - maybe you have to subscribe to do so. Pity - I would have been happy to buy it from you.
Is the accelerator module like the one I had on the KTM adventure ie something to alter the rate at which the throttles open in retaion to the angle of the twist grip?
