2010 tank venting valve GS911 output tests
mpgscott
Isle of Scalpay, Western Isles
I’m looking at a fault on a friends GSA and the bike will start from cold and run but cuts out after a while.
There is plenty fuel and no faults are shown on GS911
When I run GS911 output tests I can audibly hear all tests run audibly.
However the ‘Tank venting valve’ I hear nothing audibly when we run this test. I’m expecting to hear something like the others when I run the test can anyone confirm please?
So fuel pump fine, fuel injectors and idle actuators. Just the tank venting valve that passes but does nothing.
Any ideas??
Any ideas??
under what condition does it cut out? When on the throttle or on idle.
On the GS-911. i would run the engine and compare the readings to the expected output to see if something is not within spec.
All good guys the old one check the simple ones first. Stick in tank = dry stick and faulty fuel strip.
All good..
