Well that was easier than I thought. Took about 1.5 hours.
Shock is off the bike and ready to be sent off to T-Tech
For anyone else contemplating the job, it’s remarkably straightforward although there’s a couple of things that I found out:
a 15mm impact socket makes the removal of the top nut easy.
You need to remove the belt cover from the front of the engine to allow the shock to drop out.
The anti twist thingy is awkward but lift it up and twist and it will pop out, or remove the 2 wee screws that mount it to the shock.
Fingers crossed it’s as easy to put back together!
