2013 700GS stretch to the bars
stonehenge
Salisbury
A friend has a problem with the stretch to the bars on a 700 GS. I mentioned rox risers, but is there another alternative way to bring them back by an inch or so? As a 1200 rider, I do not know, but do you guys know of any alternative? Ta
I take it they've tried simply rotating them a bit? Won't give you an inch, but worked for me going the other way (raising them a little for when standing off road).
They should be able to put up to 20mm risers on which will bring the bars back a little without having to change the brake lines like the rox require. (this is the case for the 658 and 800 at least)
Best,
S
Best,
S
This come little late, but ROX 2" risers works fine to 700GS, I have those. And no change to brake line.
