Sold 2014 Land Rover discovery 4xs sd v6
keithquad
Kendal England
Commercial vehicle with the following:
Rear camera/sat nav/cruise control/air con/heated & electric front seats
Electric front windows (static windows in the back)
Removable tow ball
Side steps
5 seats (removable rear seats via bolts, with 2 seat belts and 1 lap belt)
Programmable Eberspacher heater
Dog guard
Boot liner
Large mud flaps
Professionally applied ceramic coating to exterior paintwork - which ensures the paintwork is protected & cleans/washes easily. Bodywork in excellent condition
1 key (other key - not presently working but is available)
Full service history available - serviced regularly by Land Rover specialist
2 owners
MOT due March 2027 with last full service in March 2026
This is a great car/work horse with no major problems and is being reluctantly sold.
Price: £5,800
Based: Kendal, Cumbria
With it being commercial what is the tax bracket please.
145k at its last MOT in March
Great as a company vehicle re benefit in kind as the same bracket as a van 😁 I had a disco 4 commercial and now have a disco 5 commercial as a company vehicle.
The other questions re what work has been carried out on it, Ill post shortly once I’ve reviewed all the maintenance that we have done.
Thank you for your inerest.
Ill attempt to answer all questions being asked:-
Ownership - We have owned this vehicle since 2015.
Servicing has been carried out by a local garage by mechanics who previously worked at the local Landrover specialist garage (charging a phenomenal hourly rate!):-
Each year or at the set mileage oils/filters have been replaced as well as the following:-
2026; OSF inlet manifold replaced
2025; rear; disc, disc pads. Brake pipes replaced rear, brake & clutch fluid replaced
2024; replace front lower suspension arms, bonnet catch, new side steps
2023; auto gear selector mode replacement, replaced steering shaft, hydraulic fluid
2022; oil filter, pollen filter, air filter
2021; steering joints greased
2019; replace throttle housing, replace rear disc/pads
In terms of known faults that the vehicle presently has:-
Eco mode does not work. Light permanently on the dash.
The starter button works absolutely fine but you need to push it in the correct spot.
The right hand extended cover of the roof rack is presently not attached - needs re attaching.
The tailgate fold down flap, which stops a gap inviting between tailgate & boot no longer has springs in it so it doesn’t always fold down.
Tyres will need replacing at some point soon-ish, there is a ‘road noise’ due to the tyres being squared off.
Other than the above the vehicle still runs smoothly. And, for its year it is in excellent condition.
Belts & water pump have not been replaced.
Belt replacement is circa £500 - should someone actually be interested then this would serve as good opportunity to discuss the price
May I ask are you interested in the vehicle or merely wishing to ask salient questions on the behalf of others!
Interested potentially hence asking.
However if you’ve got an Indy who can do the belts for you £500 then they’re losing money.
Even a good one who knows how to do it without the body coming off is £1k because of how long it takes with them being on the rear of the engine. Cheapest I’ve ever paid was £800 when it was part of a lot of other work x.
My brother in law is interested too for his surveying business. However, circa 145k miles and the front and rear belts not being done is a bit of a showstopper. They are meant to be done around 112k miles or at the seven year point, whichever comes first. I would get them done and alter the price accordingly. Anyone that knows LRs wont go near a vehicle with belts that old. Come back to me once they are done and I will let him know.
