I get that on my '05 RT, worse at low speed and when the tank is full. I check the pressures before every ride. Having said that, two expensive gauges gave readings 6psi apart, with an old draper thing halfway between the two. How do you know if a gauge is accurate? Be interested to know if there is a common cause for this.
