2021 1290 SAR - location of ACC1/2 connectors
Berin
South Oxfordshire
Anyone know where the ACC connectors are specifically on a 2021 (2021 MY) SAR? According to the Interweb, they are variously underneath the TFT, in a right hand side panel, underneath the little sunglasses holder on the tank and in the headlight, so I'd rather know before dismantling a whole load of unnecessary things!
I believe the location may, for some reason, be different on a SAS
On the 2021 MY SAR, the ACC connectors should be in the right-hand side panel area, rather than behind the TFT or in the headlight. The SAS does appear to have them located differently, which is probably where some of the conflicting information comes from. Hopefully that saves you from dismantling half the bike!
Thanks everyone- hopefully saved me taking
a load of the wrong things off!
Under the right hand side panel on the SAS as well. Also a pair under the rear seat.
The acc 2 connecter were indeed under the right side panel which was under about 100 other panels, time consuming but pretty straightforward.
