24 hour clock
duckspeed
Proud Tosser
Stockport
Is it possible to have the clock with a 24hr display on my 2006 hexhead with muti info display ?? The manual only shows with 12hr and no mention of how to change. :nenau
Spent a life time with 24hr time, and it's bugging me.:beerjug:
I would like to do the same but it is a dealer only job I believe. Hopefully someone else can confirm. I have a GS911 but it can't be done with this unfortunately.
Easy.
All you have to do is remember to add 12 to the reading if you've already eaten lunch.
:thumb
I do believe it can be done but it's a dealer job, has to be plugged in to the special diagnostic computer thingy :thumb
If you have your bike dealer serviced they should do it FOC for you, only takes a couple if minutes.
Thanks guys, i'll have a word at Williams, service the bike myself, but a couple of stella might make the difference :beerjug:
As has been said, the easy way is for a dealer to alter the settings at service, when the bike is connected to the diagnostics. It's then a set of "radio buttons" to set. They can also extend the "indicator self cancel" interval, or turn it off altogether, set TPM display from Bar to PSI, & set the ambient Temp to degrees F or C.
ahh.. snap.
Actually, I want the same thing too, at the same dealer.
I'll bring the other two Stellas!
Not on an 06 they can't
"Can't" to which bit ? We had 06 model RT's at work & they could be so altered ( & were) I run a personal 2007 RT & a 2009 GSA, & they are so configured.
I do know that when we went to T/cam's we found that you could extend the indicator "distance travelled" setting but could no longer switch it off altogether.
I don't believe that the service indicator or TPM were options on the 06 GS
Cross purposes here I think. I didn't mention Service Interval. As to TPM, you can only adjust the settings if the bike is actually fitted with them.:beerjug:
