AndyB
Was reading though my instruction manual this afternoon and found a section on cusomising the tabs on the display. Not found this before, quite handy to change them from the standard display. Has any one else had a go at changing them from standard? There is quite a large range you can select from, both for when you are running a route and when the unit is just in free wheel mode. Going to try mine out this evening.
andrew.
andrew.
