2nd Gear problem.
Scotsrick
East Lothian
I’m having problems with the gears on my 24 Trophy.
Pulling away from a standstill occasionally it won’t shift out of second into third. There doesn’t seem to be a particular way to get it to shift, sometimes if I gun it, it will shift, sometimes if I drop back into 1st it will shift, sometimes it takes several changes from 2nd to 1st to get it to change.
It doesn’t happen every time but enough times to make you think it’s quite likely to happen. It’s only from a standstill, I can change down to 1st on the move and it’s okay every time. This is my 4th boxer and I think I can remember having this trouble before but not to this extent.
Obviously it’s a warranty problem but it would be good to know that I’m not alone before I complain.
Get it recalibrated. I had similar crappy gear changes and the recalibration resolved it.
