Freeman1100GS Registered user Joined May 30, 2020 Messages 59 Reaction score 0 Location Lake Stevens Washington Oct 30, 2020 #21 here is a picture of the broken end of my driveshaft that needs to be removed. Attachments IMG_4133.JPG 100.7 KB · Views: 146 IMG_4134.JPG 104.6 KB · Views: 146
Freeman1100GS Registered user Joined May 30, 2020 Messages 59 Reaction score 0 Location Lake Stevens Washington Oct 30, 2020 #22 how do I remove that?
mouthfulloflake Registered user Joined Dec 3, 2016 Messages 69 Reaction score 0 Location Arkansas Oct 31, 2020 #23 Freeman1100GS said: how do I remove that? Click to expand... multiple wraps of a heavy nylon strap and a slide hammer maybe? if you could get a slide hammer right on it it would come right off, but that is the issue huh? some sort of a puller, three jaw clamp behind it, bury the main nut in the recess cut on the front of the output shaft and pull it off. cut a square of plywood, with a groove to the center to slide over and protect the transmission case. slide it behind the yoke. use two prybars on either side evenly prying against the yoke, have a buddy tap the center of the output shaft.
DrFarkoff Grumpy Ole Git!!! UKGSer Subscriber Joined Jun 27, 2006 Messages 14,211 Reaction score 2,230 Location Islandmagee, Co Antrim NI Oct 31, 2020 #24 Freeman1100GS said: how do I remove that? Click to expand... Have you any access to a slide hammer? That yoke should just pop off with movement towards the rear But start sprayying some release oil around those splines
Steptoe Him/Bloke/Fella. UKGSer Subscriber Joined Oct 12, 2003 Messages 73,608 Reaction score 22,121 Location S/W London. Oct 31, 2020 #25 Freeman1100GS said: how do I remove that? Click to expand... Same as would remove an undamaged drive shaft - Insert a pry bar or large screwdriver in the gap at the front of the driveshaft where is mounts on the output shaft and lever it off.
