My 2013 700GS has 10000 miles on the clock and has been running fine. Last week I did 1600 miles riding up to Scotland and touring the NW500. Performance was perfect. Yesterday I had rode about 60 miles everything perfect again.
But my problems started after getting caught in a grid locked traffic jam that took me a good half hour to cover less than a mile. I filtered when I could but for the best part of the half hour I was sitting in 26 degree heat I did switch the bike off on occasions but the cooling electric fan did come on a few times. Once I was through the jam the bike was ok but when I stopped at a set of lights about a mile from the jam, the engine cut out. After a couple of turns it finally started. But from them on when accelerating through the gears it kept missing and then firing up again. It also cut out completely a couple of times in slow traffic.
I managed to nurse the bike home (40 miles) by gently accelerating through the gears and slipping the clutch. Every now and then it would cut out and then fire itself back up. On one stage of the journey I had an open motorway so I took the bike up to 80 and it ran fine. I even slowed down and opened up the throttle in top gear to see if it would misfire and it pulled perfectly. However as soon as I got into traffic again after a while the misfire symptoms returned. It also ticks over nicely and does not misfire when revved with no load.
So it seems that the fault only comes in low gears when accelerating up in relatively slow moving traffic and the symptoms only started after my gridlock.
Can anybody help me on this one please?
