!987 r100 gs not starting
Big Jets
Glasgow Scotland
Rode 60 miles last Sunday afternon,washed the bike (sponge and garden hose not pressure wash),went to put it in the garage later on that evening and the bike would not fire up it was trying but not starting ,My first thought was that I had flooded it as I had gave it full choke as it had laid up cold for 4 to 5 hours .Any way a week down the line its still not starting ,plenty fuel ,battery fully charged ,and getting a spark at both plugs .Inoticed that occasionaly its backfiring and when you burl it over with the plug out its sparking very fast as if its about double the amount you would expect it to.Im thinking ignition system but unfortunately I dont have a donor airhead to test the components .Any help would be much appreciated Chaps .Cheers:beerjug:
On my R100gs, over winter, choke used to stick, bike would turn over ,check it's operating ok. Little bit of TLC:thumby:
If not that and you have a spark?.
Someone with more brainpower will be along shortly.
I noticed that occasionaly its backfiring and when you burl it over with the plug out its sparking very fast as if its about double the amount you would expect it to.
Remember that Airheads have 'Lost Spark' ignition - e.g. both plugs fire every revolution (not what you might expect on a four-stroke).
This means that they are firing on the exhaust stroke so, if there's un-burnt fuel & air in there, you can get a backfire.
It sounds as though you need to drop the float chambers and check for water :augie.
Good luck :thumb.
Bob.
Try dropping both float bowls and checking there's no water/blockages in the small jet in the corner where the choke takes its pick-up.
Sent from my iPad using Tapatalk HD
Thanks chaps ,looks like Ive been barking up the wrong tree Ill drop the bowls and have a look .Thats good to know about the spark Bob .Cheers
Been out and dropped the bowls everthing clean no signs of water choke pick up blowing through no problem.Let the carbs fill ,gave it full choke, nothing . :nenau:beer:
Check two small wires on coil take them off clean them and put back could be a bad connection had the same problem on the m25 at 7.30am on the way t the tunnel boy did I larf.
Steve
Had the tank off last night Jaber and gave everything a once over .Ill take it back off tomorrow and run through the connections a bit more attentively .Gonna give it a wee jag of petrol in each cylinder and see what happens .Cheers :beerjug:
Crisis over ,basically went through all the connections ,cleaned plugs ,Steptoes kettle over the carbs trick and a wee jag of fuel into the cylinders full choke and it started instantly .Happy but none the wiser on the initial cause :nenau:beer:.Pub Time I think
jeh thats what I du a lot it seems to get everry thing running againe from lawn mowers to bickes :D
