RobK
Often Confused
Hi all,
I'm having an issue with my 1150 not starting.
It was running, then I got it out of the garage, washed it, put it away. Next time I tried to start it, nothing.
There is no fuel pump whine when turning on the ignition.
I've checked fuses and relays, put a meter on the green/white wire at the fuel tank connecter and measured volts when ignition switched on, got 12ish volts for a second or so before dropping back as I believe is expected.
So it looks like fuel pump, it it toast or is there something simple I may have overlooked?
Cheers,
Rob.
Cheers,
Rob.
