Hi all,
My heat exchanger appears to be leaking but very very slowly, just enough to bleed over the surface around as opposed to actual dripping.
My plan was to check the torque of each bolt (if anyone knows the settings for the main housing and in/out flows that would be great)
Failing that is this a warranty issue? It's a 59 but i bought it used at 400 miles in May, it's now at about 1700...
Any advice would be gratefully received,
S
S
