A BIT THICK
[email protected]
up north
NOW THEN, IVE HAD BIKES FOR MANY MANY YEARS BUT I AM JUST ABOUT THE WORST MECHANIC THAT I KNOW BUT AFTER BUYING THE BIKE IM A BIT SKINT, I HAVE A 54 PLATE GS AND WOULD LIKE TO ADD SEVERAL THINGS TO IT, A CHARGING POINT FOR MY CAR BASED GPS ( WORKED WELL ON A TRIUMPH WITH A CABLE STRAIGHT TO THE BATTERY, I CAN JUST ABOUT MANAGE THAT) WILL THIS WORK ON THE BMW WITH THIS CAN BUS THING??? AND WHAT DOES IT DO, ALSO IN ONE OF THE MANY BMW SITES I HAVE LOOKED ON THERE SEEMS TO BE A DASHBOARD FILL IN WITH AN ACCSESSORY SOCKET FITTED ( DOES THIS NEED TO BE WIRED IN AND HOW HARD IS IT AND WHERE DOES IT GO TO, PICTURES WORK BETTER FOR ME THAN WORDS) I WOULD LIKE TO KEEP THE BMW SOCKET FOR MY WIFES HEATED GLOVES, WHAT BIT DO I NEED TO FIT THE GLOVES INTO THE BMW SOCKET ( DONT MIND A BIT OF SIMPLE WIRING) AS ITS NOT A CIGGY TYPE SOCKET AND FINALLY THIS FUEL PUMP WATER PROBLEM COULD SOMEONE POST A PICTURE OF WHERE IT IS SO I CAN LOOK AT MINE, IVE NOT HAD THE BIKE LONG FROM THE DEALERS BUT HAVE BEEN OUT IN THE RAIN A COUPLE OF TIMES AND YES IVE WASHED IT ( WELL £7K AND IT IS NEW TO ME).
IM SORRY IF I HAVE INSULTED THE MANY WISE AND GIFTED CONTRIBUTERS TO THIS FORUM WHO WILL SAY USE THE SEARCH SECTION, I HAVE TRIED AND JUST GET CONFUSED.
THANKS FOR ANY HELP FORTHCOMING AND IF PEOPLE DONT WANT TO POST YOU CAN ALWAYS E-MAIL ME ( DONT KNOW WHY THAT CAME UP AS MY USER NAME CAN I CHANGE IT????:o:o:thumb
ONE OTHER THING
WENT ON THE VOSA SITE FOR MOTORCYCLE RECALLS RM/2005/016 WOULD SEEM TO BE ABOUT WATER INGRESS INTO THE FUEL PUMP, BUT IT DOES NOT INCLUDED MY VIN NUMBER ,WAS THE DESIGN CHANGED AFTER THIS RECALL??? IT WOULD APPEAR NOT HOW DO I CHECK THAT MY FUEL PUMP IS SAFE, THANKS AGAIN:bow:bow
See that button.. Third up from the bottom left on your keyboard... Press this once..
There is a lot here about connecting a GPS to the 1200.
Don't get intimidated by the Canbus.
There is an easy way to do this as there is a little plug socket up at your headstock you can tap the power off.
Looking below your handlebars towards the shock there is a little socket there with a cap and nothing plugged into it. You can buy a plug to for this socket .I actually think someone has put a good post about it somewhere on the site.
Bear in mind that the search function won't work for 3 letter words (i.e GPS) so maybe do a search for plug , heatstock , canbus etc..
