A few questions on front discs washers and bobbins
er-minio
London/Rome
I am reassembling on the sets of wheels for my GS, after Mr @Slipperyeel extremely kindly and patiently re-tensioned the spokes and trued both wheels.
This is my "road" set of wheels, and when I bought them I did buy a new set of Brembo discs from Motorworks (the old discs are on the other set of wheels).
Couple of question:
Looks like I might have, at the time, installed wrong bobbins, as these are a tad short. The Brembo discs are a bit thicker than the originals. While this didn't cause any problems in the miles done so far, I'd rather reassemble everything with the correct bobbins.
Second question is regarding the spacers/washers.
The manual indicates: hub > black washer (small hole) > disc > black washer (larger hole) > spring washer > bobbin bolt.
Does the first black washer go on the other side where the reluctor ring is? So: hub > reluctor ring > black washer and so on?
I don't remember and I wanted to double check.
I also lost a couple of washers today in the process of moving things around, so I have to order some shit from Motorworks and will complete this during the week. :D
This is the front from the other set of wheels... pretty sure on these ones I just randomly threw some bits together :D and there is a few spacers missing, but will have to disassemble and re-assemble these ones as well to replace bearings, also those discs are beyond shot (original discs of the GS, >75k miles).
Hmmmm this was my original order.
The bobbins are the correct ones for 5mm discs.
I'll check if I inverted by chance with the other front wheel. That's highly probable :D
I cannot find the thrust washers (black ones) on Motorworks. I have a new set of 10 for those that go between hub and disc (smaller hole) but I need a few more of the ones that go next to the wave washer.
Sorted. I was being an idiot and slightly panicked.
The bobbins are the right size.
Reinstalled everything. I also now have RDC :D welcome to the future!
I just have to add a thrust washer - ordered.
I am going to be doing this soon. Motorworks list Brembo disc with bobbins and washers BRA16406-1 so should be straightforward.
Yep it is.
Ignore my brain fart about bobbins size above. I have two set of wheels and discs, for a moment I feared I switched the bobbins from one set of discs to the other by error.
Yes Motorworks now sells a single package that is Brembo discs + bobbins and washers all together.
