Lars1974
hi guys,
finally the temperature has been about 0 here in the UK and I thought today is a good day to prep my Uly for the new season:
so first engine oil & filter change:
1. out with the old oil after a short warm up ride...
2. out with the old filter too
3. in with the new filter
4. clean the drain plug and than re-insert, but not too tight!
5. fill with new HD20W50!
6. drain the primary oil, with the bike upright...
7. take off clutch inspection cover and than after checking the drain plug and re-inserting fill with new primary oil
8. check Air filter and also i had a quick check at the plugs, but did not change them or get them out...
every now and than my bike runs only on 1 cylinder and it looks like the front is not firing....also the around the plug (both plugs in fact) is a fair amount of oil sweat - is that normal?
here is photo of the front plug - so you can see what i mean
finally re-assemble everything here a shot half way through that
the bike is running again...
now i am ready for spring!
Enjoy and Happy Easter!
Lars
Lars
