ABS error code
Brendan
Sligo, Ireland.
Hi Folks,
I'm using a GS911 to read the ABS error codes on my 2005 R1200GS and it says the following;
"Internal Control module error, Unpermissible vehicle coding found".
This is the only error code showing. I have just replaced the ABS unit due to another fault.
Does anyone know what this code means??
AFAIK all electronic modules on the R1200 need to be set up or 'coded' to work properly together. To my knowledge this can be done only at the dealers using their GT1. Maybe give them a call?
