ABS Fault on Rear Wheel
Big Fred
South Yorkhire
Hi All,
Yesterday, some tosspot left a huge loop of electrical cable in the middle of the road and Muggins here, ran over it.
It wrapped itself around the rear wheel, wedging itself in the rear caliper, thankfully not enough to lock the wheel, but enough to make me change my kex when i got home!
I now have a fault on the rear brake that goes like this. When i turn the ignition on and fire the bike up, the warning triangle stays on, the Brake Failure warning light flashes real quick and theres no servo noise when i press the brake pedal (although there is some braking to the rear wheel)
There's also a clicking noise from the ABS relay as i assume it tries to perform the self test. Is this likely to be something as simple as changing the relay or may i have damaged the ABS Sensor? I can't see any obvious damage though.
Not sure which version ABS it is, if this helps its a 2003 1150 with Brembo calipers
Thanks in anticipation
I don't know about problem , just very happy you are in one piece , I was dodgeing a garden rake on motorway . Glad you and bike home in one piece .
Can't see why the relay would be damaged when the physical damage would have been at the back end. :nenau
Check clearance between sensor and the ring on the back wheel......make sure there's no scraps of crap in there and spin the wheel to make sure there's no warp
Also check the microswitch behind the rear brake pedal....that can get bent out of shape or knocked a bit..make sure it's free and working, you should be able to hear the tiny click as it switches.
Rake on the motorway? My mind boggles with the thought of what that would do to a bike!
Big Fred. Did the cable go between the disc and the drive i.e. could it have fouled the sensor? If yes then surely that's the first place to start looking... It would be a little uncanny if the ABS fault wasn't related to what happened with the cable...
keep us posted. We need to know what to do after riding over cables (and any takers for the rake, we'd love to hear how to handle that one!)
Thanks for replying so quickly.
Yeah, the cable was wrapped around the wheel and under the caliper ( i had to remove both the caliper and wheel to get it out ) so i guess it would have got into the sensor area. Is this easily damaged?
Maybe it's as simple as removing the rear wheel, caliper and ABS sensor then carefully checking the components and reassembling (making sure the sensor gap is correct).
I don't know if there is a diagnostic test to check the sensor when it's off the bike? Anyone know? Maybe you'll see damage to the sensor on closer inspection...
Just a thought. Is it possible the cable lashed around enough to damage other cables (radially) before bunching up around the hub? Maybe take a look
No way of testing the sensor off the bike. If have access to diagnostic tool then that will tell you where the fault is.
If need a sensor then see if THIS is for you.
The cable, as far as i know, didnt touch anything else.
How do i check the clearance between the sensor and ring, is it just the clearance checked with a feeler gauge? I assume Mr Haynes book of lies will have the correct clearance.
A diagnostic tool won't tell you much more than the bulb flashing are already doing....at best, it will say that there's a fault in a subsystem, but it won't say where or what is causing that fault.
Keep it simple.....the fault first showed up when a cable got wrapped around the wheel.....it would be sensible therefore to look for physical damage to a sensor, or whatever the sensor is, er, sensing :blast
Then you look at nearby associated systems like the microswitch etc etc.
Clever diagnostics can lead people up the garden path.......DAMHIK :rolleyes:
I think the tool kit on the bike even contains the required feeler gauge (or it did when the bike was new, anyway.)
Just had the wheel, caliper and sensor off. No damage to anything, air gap correct. Looks like a trip to Rainbow.
unplug the sensor and put multi - meter probes on the sensor side plugs two terminals put meter to ohms if it shows 0 ie open crcuit the sensor/cable is broken. :thumb
Update:
Just got back from having the fault diagnosed at Rainbow. It turns out that the Servo is fecked. Makes me think that this fault was not, after all, caused by the wire getting wrapped around the wheel. Just a coincidence.
£2000.00 fitted!:tears
Servoectomy then. I've seen plenty on here about the procedure, so that makes me feel easier about doing it.
Thanks to all who looked and posted.
Update:
Got a spare working servo if you want :nenau
