Matt Padgham
I'm hoping someone can shed some light on this!
I made the most of Sundays fine weather and decided to clean the front calipers. This seemed to go OK!
When I then rode the bike, ABS checked OK and lights went out. After a few miles the ABS lights started flashing alternately. If I stopped and restarted, ABS self check OK again but sae problem a few miles later.
Tried a rolling 4th gear on off job and than the ABS lights stayed flashing alternately despite switching off and restarting etc!
I've tried to reset the ABS, connecting wire to middle connection of diagnostic lead, 8 sec push on ABS button etc. Lights both go on to confirm reset but on turning ignition back on i get alternate flashing again.
I've also used an LED to error check (which has worked well in past) but this time the LED does not flash, stays on (slight flicker as ABS relay clicks).
What have I messed up!!
thanks in advance
thanks in advance
