Big Al Litch
2003 1150GS 2-spark with ABS/servo-brakes.
Ok, I know this one is covered all the time and I had read all the previous posts I could find but when I went to bleed my brakes today (ABS/servo) I was totally confused with what I encountered. I had read & digested all the available info and was paticually pleased with what Steptoe had written in the past and so it was with a fair degree of confidence that I started work as I am no stranger to bleeding convential hydraulic systems.
I found four bleed nipples on the unit and all seemed to be pretty inaccessable without removing the main block-connector. Also I was expecting to recognise the two mini fluid-reservoirs on the unit but but to be perfectly honest I wasn't sure if they were the two domed units or the flat-topped units c/w hex-socket.
Is it the case that the connector has to be removed to gain access to the bleed-nipples and while I can work out which controls F&R brakes which nipple does what?
For anyone with access to a Haynes mine is the unit in 17.19b on page 6.23.
