ABS/servo removal
That is the brilliant link that I used.
Do the wiring mod, very simple, you can then take out the servoABS system to reduce the bike weight by several Kgs. and leave yourself a space to carry spares or tools that you are not going to need except in an emergency.
I also removed all the original brake lines and replaced them with braided items, removed the abs sensors and rings. This does mean that you need to have a plug made to fill the hole (right through) the final drive.
why make a plug? just leave the old ABS sensor, its not like they weigh a ton ?
Didn't want the lead on there, didn't want to cut the lead:thumb
All the components I removed were in full working order and are stored should I ever want to re-install or sell them.
