ACC1 & ACC2 Wires 1290 Adventure S
Richparker
Leicester
Has anyone used the ACC1 & 2 leads on their 1290 Adventure? I've looked behind the headlight and behind the dash panel as per a couple of videos on YouTube but can't see anything. I'd like to hardwire my Garmin mount rather that use the power socket. Any info would be appreciated. The bike is a 2017 1290 Adventure S. Cheers Rich
They're there. Maybe tucked back a little.
Cut some of the cable ties (Easy to replace) and free the bunch. Don't forget to note the cable 'clear space' behind the headlight and replicate before replacing headlight.
Mine were tucked under the power socket on the left hand side of the dash... didn’t need to take anything apart - bent my fingers up under the trim, found them and pulled them out...a female bullet socket.
Thanks for the replies. Spoke to Redline KTM and they should be behind the headlight but the headlight has to be completely removed whereas I just unwound the adjuster so I could look through the gap.
