For Sale Accelerator Module F650GS and others
OldCroc
Welton nr Lincoln, England
Accelerator module for F650GS (800cc Twin). This will most likely fit the other years (2008 - 2012) and models but please check.
I believe this is an inline intake air temperature (IAT) sensor modifier. It plugs between the motorcycle's wiring harness and the IAT sensor in the air intake and contains a resistor network that makes the ECU think the intake air is colder, causing it to command a slightly richer mixture during open-loop operation. This is purported to give smoother low revs and a little more power. It is a plug and play module - no coding necessary.
My personal opinion was that it made the low revs smoother and improved throttle response and acceleration from low revs. It stopped the snatchiness at low revs.
Utube is your friend for installation. Only tool requires is a set of torx wrenches.
£25 posted yo UK address. Ppay or bank transfer.
