acceptable rear wheel bearing play?
tomodan
Member
Swindon
I am looking to buy an 1150GS and have had a look at a couple and they all seem to have (minor) play in the rear wheel bearings? Is a small ammount of movement acceptable or have I just been unlucky to look at a few with the same problem?
I am checking by someone putting weight over the front to get the rear wheel off the ground then pushing left hand /pulling right hand holding the wheel at 3oclock and 9 oclock. In every one I can fell a minor ammount of latteral movement (almost imperceptable but there none the less)
Is this what they are all like? Am I worrying about FD bearings when it just the way they are?
Please advise as I am getting a bit disheartened in my search!
Get someone to rest their foot on the rear brake
and lock the pads against the disc then wiggle it
If it moves its the pivot bearings and they can be adjusted or replaced "reasonably" easy
If it disappears it's the main bearing again No rocket science required for a change
If you have any doubts buy thru a dealer and get a warranty :thumb
If there's no rumble when you turn the wheel it'll be the paralever bearings (very common, a high percentage of bikes have a small amout of play) .
No big deal, they can usually be adjusted. :thumb
Steptoe
Thanks for the advice, could I be very cheeky and ask for you to PM me your number if you would be willing to have a chat about a couple of things for me to look for? I am mechanically minded and OK in general its just the GS isms I would like to get an expert view on?
Many thanks in advance
Tom
