Or are there similar products out there that do the same thing ?
ACF50 !00% I have used a few over the years to Combat corrosion and it sticks the pace much more than others too many to list but FS365 was supposed to be good as were some others I can;t remember now
The other thing is - They recommend spraying the aerosol into a cup, then brushing it on? WTF? Why not just supply it in a pot?
The last time I used a heavy duty protective film on a GSA - I used a semi-clear, hard cavity wax. Left it on for 2 years, but when I cleaned it off before selling the bike - the bike was absolutely perfect.
Al
There's a good comparison test here: http://f2mcltd.blogspot.co.uk/2012/01/winter-salt-protection-acf50-fs365-or.html
Would that be a product similar to Waxoyl ?
I used to use scot oil fs365 and it worked ok till the authorities started to add something else to the road salt, after that the corrosion was quite evident
I now use Acf 50 and there is never any corrosion, expensive and a bit fiddly to put on as it "creeps" so you need to be very carefull around the brakes,
Tip if you are going to spray it on heat it up in a bucket of boiling water first it transforms it![]()
It would seem the older bikes being better finished is more than an old wife's tales , the ones I have had/currently own are pre LCI have a mate who will shortly be taking delivery of his third new water cooled GS after the previous two suffered corrosion to the engine, wheel hubs & frame despite the fact that both previous bikes were professionally ACF50'd from day one and never ridden on salty roads
I prefer to use and reapply FS365 after and between every wash. As a result I've only got a small (5p piece size) bit of corrosion to the rear edge of the offside cylinder barrel of my 6000 mile old LC GSA and none to my 57000 mile 06 model![]()
So a quick update guys and took the plunge and bought two bottles for £50 from m+p heated it up and applied with a small paint brush and think I may have put in too much so maybe a cloth to work into the metal work and keep the cloth for future use ?
